Protecting (vinyl?) graphics/clear bra from UV?
wolfe
I've searched and read that 303 Protectant is quite good for general protection of vinyls,
but I'm wondering what the preferred methods are for protecting what I assume will be vinyl graphics and also the urethane clear bra material from UV/discoloration?
Also another couple of questions-
1. when applying paint sealant and/or wax to the car, should I keep it off the graphics/clear bra?
2. If I have to use different products on the vinyl than on the bodywork, which should I apply first so that one doesn't remove the other?
Ideally I want to protect the graphics, and avoid damaging them by using the wrong products.
In case it's important, the car is a mini cooper with roof graphic & factory hood stripes, and I believe the clear bra is made by 'roadblock', which I believe uses urethane.
Thanks very much for any help.
