WHAT! Deprive ourselves of standing in the searing heat with the sun baking our brains, sweat rolling into our eyes, burning while trying to do math in our heads?What kind of fun is that?
Or outlander, you can follow the gentlemen's advice above.![]()
math? whats math?:hmmm::huh:
dont you just dump it till it turns a color you like? :huh:
Well at least when you're using a flask you are working with ounces...unless you get one of those Euro models and have to figure out ml and lI have one and it only cost me 97 cents it is called a measuring flask.:idea
If your bottle holds only 40 oz, you are actually mixing it a bit strong. 10:1 with 4oz, being the 1 would mean you need 40oz. water, but in reality you are adding only 36oz, which means you are actually mixing a 9:1 solution.
At your 4:1 example, you are actually mixing 30oz water and 10 oz. APC, which is 3:1.
Another point to consider is to add your concentrate after you add your water, as this will reduce the chance of backspray/overflow as well as the likelihood of foaming the solution to the point that you have an even stronger solution, since you won't have added as much water as you were going to due to the foam produced in the bottle.
Here's a link to the measuring bottle Charles was mentioning:
HDPE Dispensing Bottles | U.S. Plastic Corp.
(At least I think this would be the one he mentioned eariler in the thread.)
It works nicely and they aren't too expensive, so you could get a few and have a specific bottle for each product you dilute. Fairly simple design and not much likelihood of stripping anything on them.
