I noticed that I had to wipe/buff the Z-16 off more than the Poorboy's to get a uniform appearance. A lot of that could be the fact that the Poorboy's dressing is also a light cleaner. Anyway, after I got any of the dressings to where they looked good they stayed that way w/o getting splotchy. I guess the key might be a good cleaning before applying any of the dressings...... hoses would tend to pick up a lot of gunk that can be hard to see on their dark color.VroomVroom said:John, do you notice any splotchiness from (I assume) heat after applying?.............
BlueLibby04 said:Maybe its time to replace them?
I usually like to replace radiator hoses and heater hoses every 60k with a good anti-freeze change. Make sure you use the proper anti-freeze depending on the make of your car.
Other than that, I use Megs Hyper dressing on all my hoses on the engine.
I haven't found the good water based dressings to be messy at all, I just apply it with a small cloth or a 4 x4 gauze pad and buff off the excess...... the same thing I'd have to do with 303. The hoses when dressed with something like Z-16 look good for about 2 years before I touch them again with dressing. Not sure if 303 would hold up that long, but it'd be worth a try..... my Poorboy's and Z-16 just happened to be a lot closer than my 303 when I was cleaning up the hoses.abbeysdad said:..........I think some of the tire dressings might be messy, so use whatever you use for dash and door gaskets. (my choice is 303)
I did say some - tire dressings come in many different 'flavors', like the silicones....and I've used Megs Endurance, a sticky gel concoction that I don't think I'd put on hoses under the hood.Eliot Ness said:I haven't found the good water based dressings to be messy at all, I just apply it with a small cloth or a 4 x4 gauze pad and buff off the excess...... the same thing I'd have to do with 303. The hoses when dressed with something like Z-16 look good for about 2 years before I touch them again with dressing. Not sure if 303 would hold up that long, but it'd be worth a try..... my Poorboy's and Z-16 just happened to be a lot closer than my 303 when I was cleaning up the hoses.
