furiousfrog
I have a 2014 blue mustang that had the hood wet sanded and clear coated to fix a corrosion problem. I have a PC and I am looking to clean up my old opticoat from about 2 years ago and possibly apply whatever new coating I can layer on top. Will optiglass work ok for this? I dont need a perfect finish and good enough is good enough. The car has some swirls under some lighting. I wont be putting the car under any special lights to find everything and I am just trying to figure out what polish and pad combos would be aggressive enough to handle OC.
I had both megs MF pads of various sizes and some optimum pads as well as LC ccs pads of various colors. What pad and polish combo will help me dig into oc to remove these swirls? I assume this will be a 2 step polish process. What should I use to finish before adding optiglass coating? I do not need perfect results but I do need something aggressive enough to do the job. If I end up removing OC completely it matters not as I will be re coating with something.
Thanks.
Thanks.
