Process?
shadybreal
As mentioned in my strong soap post, I've got 9 Chevy HHR's to do on Wednesday. All 9 are wrapped in vinyl advertisment. I'm try to find the quickest way to clean these vehicles. The vinyl really helps to hide dirt and it doesn't shine so waxing isn't not needed or allowed. Here is what my plan of attack is for right now:
Process:
Rinse entire vehicle w/ high pressure
Apply Hyper Wash via pressure washer foam gun and let dwell 1 or 2 minutes
Use shmitt on lower panels and tires
Rinse entire vehicle again w/ high pressure
Mist entire vehicle w/ DP 4 and 1 as QD
Dry vehicle w/ WW (one towel per car)
Dress tires
How does that sound? Any suggestions or ideas? Thanks!
You will more than likely be able to tell the areas you washed with the mitt vs. the pressure washed only sections. The parts of the vehicle that you only pressure wash will still have that thin layer of dirt on the surface. Of course this is somewhat dependent on the color of the vehicle and how dirty it is.
I would use one mitt for the upper halves and have another on hand for the lower portions. This way you go over the whole vehicle with the mitt not leaving any residue on the surface. Since they are vinyl wrapped you won't have to be too concerned with scratching or marring the surfaces so you can be pretty quick with it.
