Problem with MEGS NXT WAX
Dave980
Does AnyBody Find That Megs nxt leaves marks On the paint work and the only way to get them off is to do alot of rubbing. with an Mf cloth.
You need to let it dry longer and keep it outta the sun. NXT does not like the heat. Let dry for at least 30 minutes. Take your finger and take a rub. If it doesn't leave any oily residue behind, remove. I always do 2 coats of NXT. Try it and you'll see why!
make sure you put it on really thin, let it sit 30 mins and you should be fine
most problems are from people putting on a thick coat thinking it will protect more or shine better
Yeah, first time I applied the NXT tech paste, I removed it after going through the entire car and it rubbed off like dandruff, no joke. I had white crap ALL over my car and it was a pita to remove all of it. Then I realized it takes a lot longer to sit there and haze then some of the other waxes I've used. Make sure to use very thin coats as well.
Here's a pic of how thin I put it on black....
Yeah, it's on there!
After...
Are you applying it by hand? Usually that happens when the wax doesnt have an even coat put on
justin30513 said:
There. Done. Anything else?
Actually, you can have links in signatures, just not links to (or URLs for) commercial websites. You can put a link to your commercial homepage in your profile; that's about it.
Please edit your signature to remove the URL when you get a chance.
Thanks,
Tort
(moderator)
