I'm going to be doing a customer's white Mini Cooper Clubman next week and I was wondering if Prima Amigo under the Opti-Coat 2.0 will cause any issues?
Also, I see the Opti-coat can be used on plastic trim as well. Does this give the trim darkness and gloss or can I apply a trim dressing under the Opti-coat much like I do when I apply a few coats of OCW on top of the Adam's SVRT? I may just end up ordering C4 in order to give the customer a more permanent solution as this is a daily driver that isn't garaged so I want to protect it with this in mind.
Thanks!
Thanks!
