If you want a good durable finish, you can coat the hitch in a layer of either rubber undercoating from a spray can, or get it professionally coated with the spray on bedliner. The entire hitch can be sprayed down less the actual reciever hole.
I'd imagine anything else would result in alot of attention, as that area of the truck probably sees quite alot of abuse.
