Presta Ultra Cutting Creme Light for PC, or Rotary only?
new2mud
I saw a post where someone mentioned they wouldn't bother with it on a PC.
Anyone use it on a PC with good results, and if so, with what pad?
What other products' aggressiveness would you compare it to for PC applications--OC, HTEC, etc?
Is it LSP-ready after PC use?
I was wondering about this as well.
So the Light is effective with PC? What other products would you compare it to in terms of aggressiveness?
RYDAWG--would the Ultra Utting Creme Light (I'm gonna start calling this UCCL) act like IP regardless of whether applied by PC or rotary, or would it act like a more aggressive product if using rotary?
it varies and is it's own product...it's amazing by rotory, but will work great by PC. It will work great on a yellow LC pad via pc. I did a couple of cars back in the winter using the PC and UCCL.
Try the new super IP if you want to stick with the pc. It's also an amazing product.
Worked well for me with PC and yellow LC. Like the directions mention, use about a 1" stripe for a 2'x2' area. Pretty much disappears when broken down. It took out some scratches that SSR2.5 didn't faze. Cuts quickly and fairly aggressively but finishes down nicely without a lot of dusting.
