Hello,
Im looking into buying a small electric pressure washer, potentially, to help with protection of the car from salt.
But after searching here and on the interweb all over, I am unable to determine if there is any real utility gained from such a device.
So, my question is, if you have salt on a car, in the wheelwells, undercarriage, etc., does a pressure washer provide any benefit, such as superior removal of salt residues or whatnot?
Id be comparing to, say, a jet setting on a standard residential supply, which is about 60 psi.
Any thoughts on pressure washers and salt residue removal? Id assume they are better with getting junk out of the wheelwells and reaching more places, but a wand on a hose is cheaper and easier, so if it works nearly as well... what is the point? It seems like most electric pressure washers are fairly unreliable...
Thanks!
JMH
Thanks!
JMH
