AnonCanadian
Hey guys,
SO I need some help. On my 21 Wrangler, the edge is lifting on the PPF on my rear fender (only one is impacted) and this was the 3rd attempt to get them done in PPF.
How can I fix this? I can push it down with my finger, and it says for a bit, but eventually lifts.
There`s *some* dust under it, no dirt or debris otherwise... so I`m thinking of doing this:
Step 1: rinse with water/soap mix sprayed in misted
Step 2: flush it out by "wiping" down with a CC to flatten it out and knock the water out
Step 3: put light packing tape on it, attached to the fender lip (plastic trim) to hold it down over night
Step 4: remove tape, pulling from top of fender down while pushing down to ensure I`m not "lifting" at the ppf when removing
Any other tips you may have?
Thanks in advance
Thanks in advance
