I've been thinking about trying out Power Finish, but I also have M105 and Ultimate Compound. Do I really need Power Finish if I have the other two or is Power Finish different enough to make it worth getting?
I don't like Power Finish at all, so I am probably the worst person to respond to this.
Power Finish falls between SIP and 106fa, it doesn't cut as much as SIP and doesn't finish as nice as 106fa. I will work well to clean up the marring left behind from M105/Ultimate Compound, and you can finish with it on a Porter Cable/Flex. I would strongly advise wiping the car with alcohol after use as I have found it to mask defects strongly. In fact GMBlack call's it Power Fill.
