Information source:
Quote:
~One manâ€â„¢s opinion / observations~
Machine Polish / Foam Pad Combinations:
Always start with the least abrasive combination, if that combination of foam pad and polish doesnâ€â„¢t remove the surface imperfections, proceed using the same grade of polish but change to a more aggressive foam pad. Once you are satisfied that the surface imperfections have been removed, proceed by using the least abrasive polish / foam pad combination to remove the â€Ëœcompounding hazeâ€â„¢.
a. Use Iz Einzett Paint Polish and a polishing foam (LC White) VC foam
b. Utilizing the same polish, change to a cutting/polishing foam (LC Orange) VC pad
c. With the same polish, change to cutting foam (LC Yellow) VC pad
d. Remove the â€Ëœcompounding hazeâ€â„¢ using Iz Einzett Metallic Polish and a polishing foam (LC White) Flat pad.
If none of these combinations remove the surface imperfections, and only if necessary â€Ëœstep-upâ€â„¢ to a more abrasive polish Iz Einzett Ultra Polish using the same foam pads as in (1) above It is preferable to polish 2-3 times to restore the paint film surface than to use an unnecessarily abrasive machine polish / foam pad combination.
As PACO has suggested only experience will tell you when â€Ëœits as good as I can get it without risk to the clear coatâ€â„¢
The use of abrasive type polish / cleaners should always be restricted to specific problems. Most original paint finishes are tougher on the outer surface than the layers underneath. The outer layers should be preserved as far as possible. Always use the least aggressive product first, evaluate the surface, then only if necessary `step-up' to a more abrasive product.
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
