Hi there!
Finally the temperature here in Norway is hot enough to do some detailing!
So, i bought this PC7424 last year, but never got to try it until now.
I used a dual-headed random orbital until i bought the PC, never ran in to any problems really, but wanted to upgrade my arsenal and experience.
So, heres what i have done this far:
-Wash
-Clay
-Wash
-Wipedown
Then i prepared my PC for action.
I started with Medium Cutting pads, and Megs #1 Medium Cut Cleaner.
But here the problems start.
As soon as i start polishing, it seems as if there is too much friction between the pad and the paint. It stutters and won't rotate if i apply even a bit of pressure.
And it gets really hot, almost too hot to touch.
What could cause this?
I have tried adding more product, priming pad, changing pads, nothing helps.
The only pad that works is the wool pad i have. That one just cuts too heavy, i don't need that.
Since i live in Norway, we have 220V output, and i had to buy a converter. I bought a 3000W converter, which should be more than enough. I have heard of people using 500W converters.
Any tips would be greatly appreciated, as i need this done tomorrow.
And a wool pad can't remove swirls right?
Thanks alot for helping!
-Wash
-Clay
-Wash
-Wipedown
