When paint is fresh it is non-porous as the film that forms on top of it " floats " as the paint gasses out for 60-90 days after paint is applied and flashed .
Then > supposedly as time goes on , paint becomes more porous after paint is done gassing out > paint goes thru different temp and seasonal changes > different contaminents embed themselves > chemicals make contact and > nature in general including birdies and such .
Being that I used to do custom auto painting for a living though I know of 3 methods that leave the paint as non-porous as possible IF using the right final coat as well ....
1.) Properly laying more than 1-2 coats of clear at proper flash ( and being quality clear w/proper hardeners ) and having UV hardener mixed in an being an EXTREMELY UV stable / Uv/UB resistant clear ..
2.) UV curing , not heat curing . UV curing dries the paint from the metal outwards , heat is kind of like slapping it around and telling it to harden cause you said so . Most heat booths are downdraft also .. nm ..
3.) A final flow coat over the last and final clear coat . Flow coat is simply a heavily over reduced final clear coat . Usually the paint cup is filled with up to 60-75% reducer , final clear coat is flashed twice as long as required and the over reduced clear is sprayed on and is EXTREMELY smooth and glass like .
The paint has to be kept in a safe dust free environment though longer than normal after uv curing to ensure it settles properly . Then it is cut , buffed and polished and glazed with body shop safe products such as 3m's perfect-it III and Imperial line before delivered to customer .
That final flow coat won't open up much ever if done right , but of course clay should still be used after 1st year if it is a daily driver in the city etc ..
Come to think of it Po85RD would be a perfect final polish for flow coats , but no one knew about it back then ..
