Poorboys Super Slick and Suds in foam cannon
Bunky
Detailing Gnosis
I washed the truck and decided to use Poorboy's Super Slick and Suds in my Cam Spray foam cannon using an electric pressure washer (1400 psi / 2GPM).
In the reservoir, I used 2 oz to 16 oz warm water with a little shaking.
Result: The foam was decent with very good stickiness - a plus if you want staying power.
This is a good all around soap - in the bucket and in the cannon.
Nice! It is a great product. I don't have a foam cannon, just a foam gun that fits on a hose. With the cannon like you have it looks great! Do you then go and start in with a sponge or whatever or do you rinse?
Looks good, Al. I'm a huge fan of this soap. I always make sure to have a bottle of this stuff on my shelf.
This is a great soap. If you feel your wash solution between your fingers with this soap it actually is "slick", where other soaps tend to not be. It also smells like peaches or something. Gotta love that.
Cool. I am looking for a cannon to go on the end of my power washer. Did your's come with your washer? Looks good. Nice & soapy
How would you compare it in the cannon to optimum or CG HDSF? I know optimum is one of your favorites. Doesn't seem super foamy but I am becoming more and more interested in more cleaning power or lifting power from the cannon than a super foam show.
It depends on the mood and whether I am using the same soap as in the bucket. In this case, I just rinsed and then went to a regular wash. I even used a Poorboy's Chenille Wash Mitt.
It was not as foamy as Optimum or Honeydew hence my comment about decent suds but it was sticky. At some point the weight of the heavy cream suds actually works against stickiness due to gravity.
I purchased the foam cannon with the pressure washer but at the time, I did not realize how small the reservoir was. Objects look bigger than they appear. It holds just 16 oz and mostly plastic but I can foam the truck 2x with 16 oz which is plenty. I typically use around 1.5 to 2 oz soap in 14 oz water.
I have not tried the wax version. I think it has been stated it has NO additives such as waxes or other glossing agents so a "clean" soap.
