poorboys ssr1 vs 3m smr?
Dtail
I need a light swirl remover. Which poorboys product is comparable to 3m smr in terms of abrasiveness??? I have DACP and IP but i don't want to use that all the time just for taking out very light swirls. I have a SFP that i already gave up because i cannot get it to work properly. Is poorboys ssr easier to work on with a pC? which one would u guys recommend? Also, how is poorboys Pro polish? Is it comparable to menzerna FP?
The SSR line contains no fillersand IMO leaves a better looking finish. IMO it has a touch more bite when compared to 3MSMR. It is much easier to use 3M SMR as well.
PP is a versatile product, be sure to use a very small amount and allow it dry fully before removing. It leaves a squeeky clean surface. I haven't used menzerna products in so long that I don't know how to compare them.
Id rank 3M somewhere between SSR 1 & 2......SSr is very easy to use, 3M leaves incredible results on dark colors IMO. PP, use it sparingly ! You only need a little bit...If you think you dont have enough, your probably using just the right amt......
If your marks are real light, i wouldnt go as far as 3M...Go with the PP, then try SSR1, then go with the SSR2....(in that order) you dont need to use all 3 !!
