mburnickas said:Problem I see is DP does not remove dirt (as it is noted).
CG speed guy look good buy you can't apply a carnuba after. CG pro deailer looks good but you can't apply a sealant after.
I think the pro deailer you need to "water down"; 2:1.
EMazda3S said:Carnauba will bond just fine over a polymer. No problem with Speed Wipe and carnauba.
These are only QD's and can be washed off pretty easily. I would just hesitate to use a sealant over a freshly QD's surface done with a carnauba containing QD even though the amount of carnauba in them is minute, I would still insist on a good wash before application for 100% proper bonding.
The DP product mentioned is a "waterless wash" and it works very well. It does indeed remove dirt in similar fashion to Poorboy's Spray and Wipe and CG's Speed Wipe.
Sherman8r44 said:mburnickas--I wrote that article up. You CAN certainly use carnauba wax over Speed Wipe...it's just that I like Pro Detailer better of the two, so if I have both products I would go with Pro Detailer in that situation. Speed Wipe is more versatile in that anything will bond over it.
Pro Detailer can streak if undiluted...but my little review was with it diluted, so it doesn't really harm Pro Detailer to dilute it IME. IDK about you, but I like the fact that it can be diluted.
mburnickas said:Thanks. Here is one since I am looking to either buy more QD's:
JW quick wash, CG pro detailer or speed shine or more PB S&W/S&G.
What is the best when compared to these? I have PB now manybe they are all the same or just about?
I posted your post since I respect your judgement on these items. :chuckle: You are the man!
groebuck said:Seriously Duragloss - Fast Clean Shine - it is about 6 bucks a bottle, works like S&W and will boost or bond with any carnuba or sealant. Available at any carquest. It's awesome - that and Aquawax gives an awesome fast combo.
