Poorboys Polish and Meguiars P/C Pad Selection
dschribs
Active member
I'm looking at purchasing the Poorboy's Swirl Removers SSR 1, SSR 2 and SSR 3. I already have a few Meguiars Polishing pads and finishing pads (w-8006 & w-9006). Would I use the polishing pad for all of these products??
Thanks!!
Totally depends on the severity of the defects. A cutting pad is a necessary pad IMHO.I would expect that you are anticipating some serious defects if you are purchasing # 3 ?? Thats some serious stuff..SSR2.5 is a better family freindly SMR.
ok - maybe I'll hold off on the 3 for now. So if I just went with SSR1 and SSR2 I could use the polishing pad for both??
My recommendation would be to use a polishing pad for the SSR2, and a finishing pad for SSR1. However, you could use either pad, with either polish, depending on what you are trying to achieve. You could also make a pass with one of those products with the polishing pad, and then make a pass with the same polish with a finishing pad for a nicer finish.
P.S If I were to have only two of PB's polishes, it would be the SSR2.5, and the SSR1.
