Poorboys APC in Review
Beemerboy
Just One More Coat
On my last order I decided to give PB APC a try, Steve has been after me to get some...I've always believed that APC was APC...in fact I still do but his APC was something just a bit different from what I have been using.
Its a pleasant smell, not sure of what but pleasing...its a highly concentrated APC so mixing is necessary...I started with a 10 to 1 and that seemed to be perfect for me, for inside cleaning...Steve said that at 100 to 1 it would make a good glass cleaner, or could also be used in a wash bucket for cutting heavy soiled cars..I can see that playing with the dilution ratios I can use this in lots of applications...Steve can you expand on that for us here??
Its a detergent based cleaner and the good part about that is its safe on about all surfaces, unlike chemical based where you really have to watch what you spray that on.
I also had reservation about shipping of something that I could get locally...based on the strength of this APC, and dilution ratio, I can see that the gallon that I got will last some time..
All in all if you are looking for a good APC that will not make you pass out while working on the inside of the car, has excellent cleaning capabilities...this is a good choice.
Thanks Steve!
Thanks Beems! I bought some and will do the interiors soon. I need to find my spray bottles.If I can't then I'll order some from PB.:passout:
I have used this quite a bit...and you are right it is a highly concentrated mix...as I learned after the first time I used it and sprayed it straight on...and lets say I had a hard time breathing...cough cough...
But it works great...
pb apc is great to pre-treat stained micro-fiber towels as well. i keep a smaller spray bottle cut 3-1 or so and nasty stains disappear.
