Pontiac Montana Body Cladding Streaks, fixed!
CharlesW
The Rainmaker
About a year ago, there was quite a bit of discussion about my problem with streaks on the body cladding of my Pontiac Montana van.
The fix was what I hadn't really wanted to do, but now that it is done, I couldn't be more pleased with the results.:yay
Last Saturday, I masked off the panels and refinished them. It was a major project for me and if I hadn't had the assistance of a good friend, I doubt that I would have even tackled it.
The products used were SEM and I used their recommended products and steps.
First, we cleaned the panels twice with a degreaser and wax remover, then used the SEM products according to the following instructions they e-mailed me.
1. Clean all surfaces to be recoated with 39362 SEM Soap, along with a
gray scuff pad. (We did this twice.)
2. Apply 38353 Plastic/Leather Prep, then remove with a clean, lint-free towel, wiping in one direction only. (This was a cleaning agent so we did this twice as well)
3. Apply a light coat of 39863 Plastic Adhesion Promoter, allow to flash 5
minutes, then apply a wet coat. Allow to flash 10-15 minutes, but no longer than 30 minutes before topcoating.
4. After the final coat of 39863 Plastic Adhesion Promoter has flashed
properly, apply a light coat of Bumper Coater and allow to flash for 5
minutes. Apply one or two additional coats, allowing 5 minutes between
coats. You are now finished with the recoating process.
In my case, it took 7 coats for complete coverage. I went ahead and applied a total of 10 since that used up all the Bumper Coater. It's quite possible that I didn't apply heavy enough coats to get the coverage, but I didn't want any sags or runs. I had none and it is close to a flawless finish.
Total time was about 5 hours, but at least 1.5 to 2 hours were in the masking and the removal of the headlight/parking light assemblies to do the front bumper and final clean-up.
I would recommend the SEM system, but I do think using all the products as recommended is a good idea.
It doesn't take much of the soap, plastic prep or adhesion promoter. I needed only one of each. I did use 5 spray cans of the Bumper Coater, though.
I didn't post any pictures. It looks good, but it should since they are newly painted panels. :)
Charles
Charles...I have been very pleased with the SEM products..I have used the INTERNAL PANEL COATING for doing the bottoms of the door panels where water collects...and in the tailgate of the truck ...
Plus I used their undercoating....on rocker panels...frame..behind metal bumpers...these are places i seen rust over time ..so added some protection..
they are quality products....The Ford mechanics even recommend them
AL
Congratulations on a job, that I am sure is well done.
Hopefully I will be able to see it first hand sometime after the 11th of November as I pass thru your lovely little area in Iowa.
