Got a question for the pro's here on Autopia.
I work at a car dealership and I was talking to the painter in our bodyshop. He said that to remove swirl marks you really only need a soft foam pad and water. He said if you want a super shine use some glaze after using the same actions as with just the water. Then use just water again. He has been doin it for years and it looks awsome after.
He said all the stuff like Mequires is just a waste of money. He said don't get him wrong they do work but there is no point.
If he needs to take a scratch he uses a different compound called G3 and he just puts a tab of this stuff on the area that needs it runs the circular polisher with a wool bonnet to get it out then uses the steps above.
The products used are called "Fereca"(totally spelled wrong).....lol
they are from England. The Glaze/polish is called G10 and the Compound is called G3
Anyways what he is tellin me is that bottom line to remove swirls you can use polishing pad and water, you don't need anything else.
Anyways just trying get some feed back............
Thanks a million..............................Clint..... ... . . .. .. .. . .:nixweiss
