I just polished my entire Brilliant Black Crystal Pearl Grand Cherokee with Optimum Finish Polish and only Lake Country Tangerine Hydro-Shreds on my Makita 9227C, and it turned out incredible..
I polished all the plastics the same way and had to put extra pressure on the Rotary to get the last tiny scratches out of the tail lights, and they all came out..
This product is very, very, fine and it will also leave an incredibly clear, very glossy finish if you take the time and work it for awhile..
This product did NOT introduce any extra marring, etc., onto the paint or plastics..
My process on the entire vehicle was 2 full passes, making each pass as long as possible by spraying the surfaces when they started to dry up
I worked the surfaces each time, until there was nothing left on the paint or plastic parts..
This product will not break down completely but will work and then when you let up on the pressure, it will polish but you need to work it for as long as possible to get the most out of it and your pad..
Oh and of course, I did not leave any swirls or holograms, etc.; have to keep the pad flat, moist, and don`t need more than 1,000-1,200 rpm to achieve this in my experiences.. Make passes all the way to the end and smoothly come back, overlapping that pass and keep going, repeating, keep the surfaces moist enough to allow you to continue, let up when you see you are running out of product, and it will be stunning when you wipe off what little is left..
My bottle of Optimum Finish was stored for a little while and it somehow got cracked and a clear liquid leaked out of it for a bit..
This is probably why it wanted to dry out on me sooner so I had to make up for that with a little spritzes of pad conditioner so I could get the longest work time..
I would say this product is everything that CarPro Essence is today but a few years earlier; (but it does NOT leave any product behind in the paint to improve it), and without the hassle of ruining all your microfibers because they get crunchy with bits of dried glass from the Essence in them...
Good Luck !
Dan F
