Polishing marble?
So as I was brushing my teeth this morning, I came upon a horrible sight. The marble countertop in the bathroom looks worse than a 10 year old neglected paintjob. A large amount of scratches, scuffs, waterspots, etc etc. Can anyone recommend a polish to me so that I can try to get this stuff out?
Nicsand has a liguid polish-10,000 grit that is designed for hard surfaces- also the Nicsand polishing discs for drills. Not sure if anyone local to you would carry it but I've seen it available on Ebay
I recently tried with my rotary on synthetic ( cultured?) marble bathroom counter. Didn't do a thing other than brighten up the scratches more. :(
Neothin- Is it cultured marble or natural marble? I see the cultured stuff getting marred up much easier than the natural stone. The countertop in our guest bedroom is cultured marble and it's more marred up than the countertops in the rest of the house.
LightngSVT said:
Does granite have the same problem? We are getting granite countertops in our new kitchen and master bath.
Short answer: lucky you, don't worry :xyxthumbs
We have both granite and marble countertops (and fireplace surrounds and some granite floors). You'll get some marring over time but granite isn't as fragile (and I'm using that term sorta loosely) as marble. Our granite and marble wears like, well, stone :D
In my experience, if you apply the same sort of rules we use on cars (don't rub abrasive dirt into it, don't drag hard objects across it) you shouldn't have much trouble. Abrasive relative to stone is pretty abrasive too BTW! We've been in this house for five years now, and the worst marring on our granite/marble was caused by the workmen :furious: before we moved in. We're not super careful with any of our granite/marble surfaces either, no need to be. Well, we try not to walk on the granite floors with stones stuck in the soles of our shoes, but that's about all the thought we give it.
Heh heh, people said I'd have to do all sorts of stuff to keep it nice but that wasn't the case. I don't do anything special to the marble/granite, I just clean it regularly with either Cinch two-in-one or Lysol Kitchen Cleaner, using the soft Scotchbrite pads for any real scrubbing (kitchen) and sponges and MFs. No buffing, no sealing, no fancy treatments and no problems at all- still looks like just like it did when we moved in and you know how I am about stuff's condition ;) And no, my wife's cosmetics haven't stained the countertops in the master bath and it's a color that would show it. The natural stone stuff is great, one of the best decisions we made when we did the house.
Granite is much tougher than marble so it won't scratch as much or as easily but it will scratch and chip if abused. Never, never, never use a stone countertop (or any countertop other than wood butcher block) as a cutting board! (This will destroy countertops and knives.) Avoid banging and dragging heavy metal objects like cast iron cookware on it.
Due to its much tighter grain structure granite is also far less susceptible to stains than marble (which stains very easily).
As with paint, when polishing stone you can either polish contaminants off the surface or polish out surface defects. Polishing contaminants off the surface is very similar to cleaning paint. Polishing out surface defects is kind'a similar but stone is much, much harder than paint so the stonework industry has its own entire world of abrasives, compounds, buffers, etc.
PC.
Synpol works great and lasts very long. It has chemical properties to it and does not have any abrasives so no worries with black or smoke grey marble / granite...
