Need some guidance. I will be buffing/polishing a hood I just finished painting. Used Dupont BC/CC (7900S clear). I have finished final sanding the hood and used 2500 grit as my final sanding. I have a Milwaukee buffer and a Porter Cable orbital polisher. Yes I am proficient with the buffer and my basic questions are what are the appropriate compounds to use. I have and was going to use the following. 3M Perfect it II 05937 with a lambs wool pad to start, them clean and move to Perfect it II foam polishing glaze 05996 with a foam polishing pad, then finish with a hand glaze. I am open to suggestions on the hand glaze as to what type. For no specific reason I was going to stick with the 3M product line because I have the first two products already. Trust me I am open to all suggestions/comments. If its of any value the color is a Torch Red, and yes I am very critical of any surface fine line scratches.
