dschribs
Active member
I've removed most of the swirls on my vehicle with the 105/205 combo. I wanted to try and "amp" it up a bit with Menzerna PO85RD. Because of the 105/205 short work time, I think I've gotten spoiled and might not work the PO85RD long enough so that I get the full benefit of the product. How long a work time would Need for PO85RD for say an 18 x 18 section?
I know the best bet is basically work the product until it's translucent but about how long would that be? I'll be using a PC and a LC black pad.
Also, what do you guys recommend in terms of priming pad with PO85RD? Should I prime the pad with product (similar to the KBM) or just hit the pad with a little quick detailing spray prior to polishing??
Thanks!
Thanks!
