BlackHowling
hi guys,
whats the best orbital polisher that you can plug into the car's cigarette lighter?
thanks.
thanks.
BlackHowling said:hi guys,
the reason i asked is i have a car that is parked in a parking garage where there is no power outlet nearby. that's the only place that i can do the waxing. my car is new and i don't think i need a powerful polisher to remove swirl marks yet.
i know the porter cable is THE polisher of choice but it doesn't suit my present need.
any recommendation is highly appreciated.
thanks again.
3Dog said:
Jesstzn said:Basically the one I was talking about .. less money because it is US funds and only 1 battery .. But should get by in a pinch.
Scottwax said:None. Best bet is a Porter Cable and a power inverter. A PC doesn't draw a huge amount of power.
Seriously, any cheapie 12V buffer isn't going be strong enough to remove imperfections. Maybe adequate to apply wax though.
Name plate says 3.7 Amp .. whats that 444 watts? I can't remember the factor. 3.7 x 120 ??BlackHowling said:hey scottwax, great idea in using a power inverter. how many watts does a PC require? the power inverter needs to be able to handle that right? i looked at the PC manufacturer site but it didn't mention how many watts.
Jimmy Buffit said:If you simply want to apply and remove wax, I think a machine is overkill.
The really nice carnaubas (Souveran, S100, P21S, etc.) go on like butter, and come off even easier. I can probably have the car done, by the time I get a tool, pad, and cord ready to go (and put away).
Plus, they tell me it helps you to bond with your car...
Jim
TOGWT said:~One man’s opinion / observations ~
Jesstzn the conversion is correct (444 Watts)
Watts= Volts x Amps
Amps= Watts / Volts
~Hope this helps~
