Easy Car Cleanup: 5 Simple Steps
Whether you're returning from a car trip or planning one, try these 5 simple steps to help keep the interior of your car neat and tidy. :suspicious:
1.Remove everything! Before cleaning the interior of your car, remove all items. If you’ve just returned from a trip or if your car is especially cluttered, place the items in a big plastic bin to sort through later. Clear rubbish from the ashtrays and check underneath the seats for loose change, etc. Remove the floor mats and place them temporarily in a dry place (not on wet grass or on oily pavement).
2.Vacuum the floor. Using the long-handled attachment, vacuum the carpet, reaching under the seats, around the pedals and in the area between the front seats and the central console. Switching to a soft-brush attachment, vacuum the dashboard and doors, taking extra care not to damage knobs and vents. Use the same soft-brush attachment to vacuum the seats. (Leather seats are easily damaged, so avoid scratching them with the vacuum hose.) Outside the car, vacuum the floor mats you’ve removed, give them a good final shake and then return them to the car.
3.Shine windows. Inside and out, back to side to front, your windows have probably taken a beating from road travel. Reclaim a crystal-clear view by removing grime, dirt, fingerprint smudges and smashed bugs. Windex® Original Glass Wipes provide a quick and convenient way to get a streak-free shine. For best results, glass should not be in direct sunlight or hot to the touch. Keep a pack of Windex® Original Glass Wipes in your glove compartment for quick touchups.
4.Clean seats, door upholstery and dashboard. Keeping vinyl and leather car seats clean and conditioned protects them from cracking. First, brush off any loose dirt or crumbs and then spray on Pledge® Lemon Clean; then wipe gently with a soft, clean cloth. (For convenience, try Pledge® Wipes.) If you have cloth seats, use a steam cleaner (you can rent one from many hardware stores). If your ceiling is upholstered, start the steam cleaning there and move downward. Any family with kids or pets should invest in an upholstery brush to tackle stains and pet hair. (An old toothbrush can work well, but make sure any brush used on upholstery is soft.)
5.Refresh the air. Is the smell of too many greasy French fries lingering inside your car? Now’s the time to refresh the air and even introduce a new scent. Try a product from Glade® Tough Odor Solutions Collection.
Ron Ketcham said:Some are using a higher grade of the resin, others put the max amount of resin in their product (IE why some cost more than others and last longer) and others just add a thickening agent to make it appear to have more resin content..........
By the way, the rule of thumb for the max amount of resin is around 30%.
Ron Ketcham said:.. all [original Armor All] was was dimethal silicone fluid, and emulsifer and water.
Yes, due to the dimethal silicone would accelerate the plastizer loss from vinyl, but everyone loved the look.
In the either late 80's or early 90's, there was a lawsuit regarding how it negatively affected rubber and vinyl.
They changed the formula to a water based aminosiloxane resin...
