TnM6i said:NXT is the best that I have found and I've tried all the major brands. I was a long-time IG groupie until NXT showed up. Used it once and never looked back.
MCA said:If you go through quite a bit of windows cleaner then I highly recommend Meg's Glass Concentrate from the Detailer's Line. Very inexpensive when you consider that a gallon can be diluted with water to make 11 gallons of solution. In addition, I find performance to be equal (if not better) to NXT glass cleaner - however, NXT can be found OTC.
areaseven said:Meguiar NXt Glass cleaner smells like Key Lime Pie (instead of IG's chemical odor).
John Styrnol said:Well, I've tried EO 20/20, don't care for it, tried IG nice product, but will not buy again. My next buy will most likely be FK1 228, but you have me intrigued about NXT glass cleaner, might buy some, maybe.
94BlkStang said:Curious what you didn't like about IG as I have had great success with it and has definitely been a top performer in my arsenal. I'll probably pick up some NXT Glass Cleaner for comparison though.
greer said:NXT seems to be the top choice, but will the bubble gum odor be too much for my cars interior?
greer said:Any comments about the smell of NXT window cleaner?
Does it make your car's interior smell fruity?
