So I'm due for a new set of brake pads/rotors for my car and I need your help and experience.
I'm going to be purchasing a set of OEM Brake Rotors which I would like to send out for plating. The two processes offered are CAD Plate or Nickel Plate. The purpose of the plating is protection of areas which are not in contact with the brake pads to insure they look "OEM New" and don't rust/corrode over time. The car won't see rain and isn't a daily driver but I do drive it. Water will be introduced to the rotors either from mild wheel cleaners or Final Detail. The pads will be either Metal Masters or Kevlar Compound, both are low dust.
A local shop will Nickel Plate all (4) Rotors for $90.00, they stated that Nickel will offer better protection over CAD..:nixweiss I'm searching for a CAD Plate Shop to determine pricing.
Has anyone tried either plating material and do you have any other suggestions. Painting is not an option BTW, it won't match the machined metal finish and judges will deduct points. I am willing to pay more for the better solution, these rotors will be on the car at least 4 years so it needs to last.
Your suggestions and thanks in advance for your time.
