Pinnacle Safe Scrub Pad vs Burnt Rubber
512detail
Not technically a review just more of a share.
Pinnacle Safe Scrub Bug & Tar Pad
This thing is so useful.
uses so far: bugs, tar, and a seperate one for cleaning polishing pads
But what can it do for my typical sunday track cleanup....why not try?
Fresh MT Street Comps on the fenders (on top of pbl v1 x2)
Only 4 passes so not too bad
Dp foam
One SOFT swipe
Then a quick rinse
Dried
No rubber
Ta da!
A little more agitation required for the plastic at the bottom but its not coated.
Didnt even bother with the rubber innside the fender wells. That is another days problem.
Summary:
I keep finding uses for this thing. I'm going to have to buy a couple more now. works great for post track cleanup of rubber on the fenders!
Did it scratch? I didn't see any marring
Easy to use? oh yes, barely any pressure---its actually more difficult to clean out the rubber than take it off but that is just a solid hose stream away from being cleaned
-Just make sure you use lots of soapy water. The honeycomb texture will do the rest.
Thanks
