Pink Moose vs Poli-Seal
colin_ming
This is my first post after learning so many things from Autopia. Thanks for all the infomation here:bow. Right now, I'm kind of confused between the Pink Moose vs Poli- Seal. Since Poli-Seal is an AIO product, how is it compare to Pink Moose? Do I use it after SIP-FP or just go after SIP ? What I found that people use carnauba after Pink Moose and Sealant after Poli-Seal. Or other different things to concern between this two? Thanks.
Colin
the major difference between them is Pink moose is a finish polish & glaze mix
used to save a step, it will need a LSP and an Nuba is a good choice
as it will bond over the glaze
poli-seal ia a one step(polish & LSP) and can be use all by itself
What Jim said.
Poli-Seal is also more sealant friendly if you do decide to use something over it. Poli-Seal also has somewhat more correction ability.
Thanks for all the help:thx. I just placed an order for the pink moose combo and the CMW from Clearkote:woot2:. I'll try this first. Next time, I will try some poli-seal+opti-seal.
Colin
Scottwax said:
What Jim said.
Does that mean it's not good with OCW since it's carnuba product.
