PC vs Hand with XYZ Wax
ptim
Will you achieve the same results by using “XYZ Wax� by hand or a PC. I’m assuming that a PC will work the wax better than by hand.
If it is a pure wax, I think many here will recommend application by hand. Nowdays most waxes are so easy on/off it really doesn't take long. It is also pretty easy to spread a consistent, thin layer by hand getting good coverage. If you apply by PC you'll likely require more product as the pads requires some arbitrary amount to prime.
If you are going to apply a cleaner wax, AIO, or anything with some polishing abilities the PC is a perfect choice.
Usually I apply paste wax by hand and if I want an better more even coat I go over it again with a damp finishing pad and the PC on a low speed.
If you're just waxing, it'll work the same either way. The advantage by machine is a more uniform application, thinner layer, which helps alot when buffing it off.
Some waxes clearly state that applying by hand will get you the best results, Natty's being one of them. Souveran paste can be applied either or. If anybody has more sampes of machine vs. hand waxes, I will highly appreciate it.
