May 31, 2003 #1 G goixiz New member IS there a write up n what type of pads for which type of application I have two pads - lambs wool (hook and loop) and the white foam pad (came with PC). what other pads do i need and what speed should i use it for each pad ? thanks
May 31, 2003 #2 E Estoril ///M New member Great write up. You will probably only need the yellow cutting pad and white polishing pad from CMA.
