~One mans opinion / observations~
·To polish glass surfaces (see note) apply a quarter size amount of Autoglym Car Glass Polish™ or Groit's Fine Glass to dry 100% cotton or Microfiber cloth or a foam pad attached to a
·Porter Cable random orbital buffer set at speed # 4.
·Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
·Go over the glass several times in each direction, glass will polish virtually residue free.
·Before cleaning door glass, open the widow half way. Clean the top and the leading edge of the glass as these usually sit in the door window tracks. Wipe off any residue, and polish with a clean dry 100% cotton Microfiber cloth.
·Inspect glass for clarity and smoothness. Repeat if necessary.
Note:
For deeply etched water spots' or pits (caused by sand or road stones) in the glass surface, do not attempt to polish them out, consult an automotive glass vendor as glass used on later model cars is soft and thin (this may vary by manufacturer) due to weight / cost savings by vehicle manufactures and polishing could cause glass to crack. Some windshields and mirrors have a tinted plastic coating or a blue tint that will scratch or be damaged, only polish or use synthetic wool on uncoated glass.
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
