I also have SSR2 so I will start with the ssr1 and if not satisfied go with the ssr2! Thanks for your suggestions!Accumulator said:Yeah, try the LC white, the yellow is too aggressive a pad for something as mild as SSR1. I'd use a more aggressive product with the white pad before I switched to the yellow one. Don't worry about the PC being too aggressive, if anything you'll find it's not as aggressive as you'd like. While I haven't tried the SSR1, I suspect that it'll be too mild for what you're doing, though it should make things a little better.
After trying different combinations I found success with a white Edge2000 pad using SSR1! The cleaning scratches are gone! Thanks for your suggestions!Accumulator said:Yeah, try the LC white, the yellow is too aggressive a pad for something as mild as SSR1. I'd use a more aggressive product with the white pad before I switched to the yellow one. Don't worry about the PC being too aggressive, if anything you'll find it's not as aggressive as you'd like. While I haven't tried the SSR1, I suspect that it'll be too mild for what you're doing, though it should make things a little better.
I first use a grey spot pad(LC) with SSR1 with no luck, I then used SSR2 with this same spot pad with no luck. I switched to my Edge2000 green pad with SSR2 and I did remove cleaning lines/marks but introduced MANY swirling micro marks. I switched to Edge2000 white pad with SSR1 and this was just the ticket! Paint is near perfect.Accumulator said:yankees1- Glad you got it all fixed up! Now you'll feel comfortable using the PC on future details :xyxthumbs
I'm pleasantly surprised that the SSR1 was aggressive enough. People are always saying how hard the paint on their 'vettes is (and I never had to do any real correction on the C5 I had), so I wasn't too optimistic.
Sorry to get everyone SO EXCITED! :clap:MorBid said:PC or Hand Job:
What a title for a thread![]()
