Wharf Rat
I just ordered 3.5" Backer and 4" LC pads for my PC. Do you guys run the "stock" counterweight with this set up? I have a heavier weight for the 6" pads but never saw a weight for the four inch set up.
i didnt think a counter weight was needed in a 4 inch pad application ? i thought u had to remove it when using the 4 inch "oem" pad ?
ok nevrmind i was just under a wrong impression ...
the counter weight on my machine says use for 5 inch pad only ... so should i really go get 5.5 inch pads if i can find them out there ?
ok so using the 5 inch pad counterweight wont cause any problems when i will switch to a 3.5 in back plate and 4 in pads ?
Nope.
