PB Natty Blue instructions?
Wheelman916
Anyone have any words of wisdom for applying Natty paste wax Blue? I finished my second coat of EX-P today, and after letting that cure for 12-36 hours, i was gonna go at it with the Natty's...
So, how should this be done? Anything particularly tricky to know?
-applicator? should it be primed/moistened?
-should the whole car be done at once? or done one panel at a time?
-wipe on, wipe off? or allow to dry for any specific amount of time?
Sorry for the newb questions but I wanna try and avoid any complications like i had with the PB BH and EX-P...
One of the easiest waxes to use.
I do 1 spray of QD on an applicator, then wax.
Do the entire vehicle then wipe off.
Step back and admire.
I like to work Natty's this way.
1. Spritz a pad with QD.
2. Work in a bit of Natty's to "wet" the applicator. I prefer a wet application, but you must keep the film thin.
3. Apply Natty's to the entire car, making sure to use 3 passes over each surface with the pad. (keep it thin and go slow). Never hurry the wet application.
4. Use an XMT towel short nap side to cut into the Natty's. I use two towels to cut away the film. After initial removal, I use another XMT towel plush side to final buff and wipe. Again, slowly wipe away then buff with a light touch just enough to even it out.
5. Never get in a hurry, never use pressure. A medium touch to remove, a light touch to final wipe and buff clean.
6. After you're done with the first layer, you'll be itching to do it again. Be careful, it's addicting. Use as many layers as you like.
2 noob questions....
1st would the same recommendations be applicable towards Natty's Red too?
2nd could you please elaborate a bit more about what you mean here...
Thanks.
Damp applicator spread wax as thin as you can go let haze (finger test works good here lightly swipe your finger on the haze and if it comes off its ready to be wiped off) then buff off.
1st would the same recommendations be applicable towards Natty's Red too? Yep
2nd could you please elaborate a bit more about what you mean here... He means just do 3 passes over the same spot when you wipe it on just like you do multiple passes while polishing
Thanks.
