T
TOGWT
Guest
Surface Filling / Masking Abilities
Every polish that uses oils or polymers for lubrication will? fill? surface marks that are not removed and mask defects. If you don?t remove the lubricating oils with a wipe-down then you are by passing the post polish inspection and the oils left behind will mask the defects.
Note ? some polishes contain specific products (i.e. Kaolin (china clay) or Diatomaceous earth) to mask surface marks (evidenced by excess dusting) this type of filler will also be removed by the IPA wipe-down process.
Wipe-down after Polishing/ Compounding
Wiping the finish with a Micro fibre cloth you may feel that the swirls have been removed, only to have them reappear when applying the final wax or sealant. After polishing a section, mist and wipe to fully remove residues and reveal the true paint finish.
a)Polymer sealants will not form a proper monocular bond with a paint surface if there are any oils present and it will affect durability.
b)Silicone will cause surface smearing and will affect durability
Wipe-Down Process
Anhydrous Isopropyl alcohol [Molecular formula C3H7OH: Proper Name: Isopropanol] contains approx. 99% isopropyl alcohol, is a colourless liquid with a pleasant odour. It is highly flammable. After the paint surface has been subjected to a chemical cleaning its protective layer (s) have been removed and the paint surface left without protection, so it is very important that a wax or polymer protection be applied immediately.
Methodology - Fill a fine misting spray bottle with a solution of 1:1Anhydrous Isopropyl alcohol / distilled water, spray the paint surface, and agitate before wiping the paint surface with a clean, dry 100% cotton micro fibre towel( if it flashes too quickly (hot surface or environment, use a higher dilution rate)
Note ? a strong concentration of alcohol (or a strong solvent) will fill the paint micro pores and cause the majority of paints to swell and may be detrimental to its durability
Surface Inspection
Inspect your work under full sunlight or purpose-made paint inspection lamps; holograms, fine marring hooks, etc. are very difficult to see under man made light. There's nothing more frustrating than having to strip off your LSP and re-do. General lighting - double head with 2-300W halogen bulbs in each
1.Brinkmann REI - most LED?s merely glow, but Rebel's highly efficient, finely focused lens casts a 40-ft. beam of far-reaching light. Fish-eye-shaped lens focuses the light from the single white LED bulb into a bright, consistent beam; no dark spot in the beam's centre, the LED bulb is nearly indestructible and draws very little power, greatly extending battery life; runs on two AA batteries, included, a tough ABS plastic is armoured with thick, no-slip rubber grips Push-button on/off switch inset in the back cap REI
2.The 3M Sun Gun? Colour Matching Light - can be used throughout the refinish process, the percentage of light vs. natural day light is CRI (Colour Rendering Index) = 99.35%: identify paint defects such as swirl marks, burn through, sand scratches, etc., which will reduce the chance of costly re-work- TCP Global or Autobarn
3.Infratech CM5300 ? Colour Matcher - this light is a great alternative to the 3M Sun Gun. Runs on mains electricity not batteries, a must have tool and it?s also an inexpensive investment. High Colour Temperature 5300K Duplicates Natural sunlight under any condition, high power 70 Watts, large coverage area, hand held lightweight, momentary "On/Off" switch, identify pre-or-post paint correction / renovation defects, eliminate re-doing or call-backs ?Infratech
4.Coleman LED Rechargeable Spotlight - will run 1.5 hours on a full charge- or continuously when plugged into the included 120V/12V adapter. The spotlight sheds a super-bright 500 lumens of light with 3 XR-E LED?s. Designed to be durable and shock-resistant, the spotlight includes a side switch for easy hands-free continuous operation. 530 Lumens, operates 120V & 12V adapter (included), LED?s keep spotlight cool to the touch, Integrated hanging feature for multi-functional use, comfortable non-slip grip, includes side switch or continuous ON operation, runs continuously when plugged into the adapter.
5.Digital Microscope - this enables you to analyze and capture paint surface defects, the unit?s interchangeable lenses provides it with tremendous versatility. With the 0-10X lens, it becomes a high-quality video camera. Magnification can be increased to a startling 200X power in a matter of seconds (50x seems to be a good magnification for detailing work) the lens mount is an industry-standard C-Mount that will accept third-party lenses. ProScope HR? CSI Science Level 1, includes- 1/0-10x Lens, 1/50x Lens, 1/Carrying Case ProScope? HR Digital Microscope
Wipe-Down Process
Surface Inspection
