togwt
The Old Grey Whistle Test
Vehicle manufacturer studies have shown that failure to remove environmental contaminants, like imbedded rail dust, acid rain, industrial fallout and other environmental contaminants from paint film can cause premature degradation of the paint system.
Schedule: annually, dependent upon environmental conditions and vehicle exposure but more often on light coloured paint. To optimize the reflective properties and appearance of the paint surface, it is best to regularly remove both imbedded and surface contaminants and dirt.
There are three distinct type; Abrasive, Chemical (solvent)and Chemical(neutralised acid )
a) Abrasive
Detailer’s clay Automotive clay is not a replacement for polish or a compound; it is a pliable, petroleum resin product, containing a mild abrasive(s) i.e. kaolin, silica sand, calcium carbonate, alumina, ceramics quartz and also silicon carbide that polishes and exfoliates bonded surface contaminants.
While clay products are useful for overspray and cleaning surface contaminants, it cannot permeate and deep clean the pores of the paint
These abrasives are extremely small with an average particle size of 1- µ (micron) dependent on the aggressiveness required, mixed in with a powdered synthetic detergent. The abrasives 'shear' the surface contaminates, the sheared particles are then encapsulated by the clay (i.e. the top of the metallic particle leaving the rest embedded in the paint, which acts as a conduit for moisture to the various paint layers, allowing it to continue generating corrosion damage)
1. Zaino Z-PC Fusion Dual Action Paint Cleaner - a water-based formula with tri-particulate, diminishing abrasive system (no fillers or oils) that removes minor scratches, swirls, oxidation, wax build-up and other surface blemishes, ideal for polymer sealants
2. Dodo Juice Lime Prime Pre-Wax Cleanser - is a pre-wax cleanser formulated to clean, polish and prepare the paint surface ready for a layer of Carnauba wax.
Both these products contain mild abrasive so will help to remove light swirl marks and scratches, used with the right pad combo can help remove more stubborn marks, including blemishes or stains on the paint
Formulated with solvents and / or very fine abrasives (Kaolin or China Clay) to remove old wax, embedded dirt and light stains from paint; they help to restore gloss and remove light surface imperfection. They are designed to be used as often as required without measurably reducing paint thickness. Some paintwork cleaner’s act as 'All in One' products, so not only do they clean and polish, but also provide limited protection
b) Chemical (neutralised acid )
AQuartz IronX - use on car paint, wheels and glass (safe for all wheel finishes including painted aluminium and alloys) to remove iron filings and ferrous-based contaminants. Automotive paint is porous, by using an acid salt solution on the paint surface the micro-fissures (‘pores’) are expanded by an exothermic reaction.
This releases ferrous particles and caustic compounds that have developed in the paint's subsurface; the exothermic reaction agitates and loosens the particles allowing them to be rinsed away. Unlike clay that only removes the particulates that protrude from the paint by abrasion
These are one-step, highly effective vehicle paint decontamination, beyond what can be removed by washing or claying, with the cleaning power of an acid with a pH of 7.0, by using a neutralised acid salt
It is really interesting to see the amount of iron particles residue that will be dissolved by Iron X, despite having clayed the car before hand. This product definitely offers advancement in paintwork decontamination. 100-150ml per vehicle
Sonax Full Effect Wheel Cleaner - use on painted wheels and glass (safe for all wheel finishes including painted aluminium and alloys) to remove iron filings and ferrous-based contaminants. Automotive paint is porous, by using an acid salt solution on the paint surface the micro-fissures (‘pores’) are expanded by an exothermic reaction.
c) Chemical (solvent)
P21S® Paintwork Cleanse - a gloss-enhancing chemical cleanser that contains fillers (Kaolin or China clay) will remove old wax, light swirls and oxidation. It can be applied by hand or with an orbital polisher. Paint cleaners are designed to remove old wax, oxidation, embedded dirt and light stains from your paint surface. They can remove micro-marring of the surface (i.e. light towel marks) but typically will not remove imperfections that require levelling the clear coat, but can remove some oxidation and mineral deposits.
Swissvax Cleaner Fluid Regular is an advanced non-abrasive paint preparation solution containing mild chemical cleaning agents and heavy glazing oils that fill and mask minor paint defects and are simply unrivalled in terms of producing a perfect oil-rich surface ready for Swissvax wax protection.
Autoglym HD Cleanser - when waxing, it is important to ensure the surface of the paintwork is “deep cleaned� to remove all traces of road grime, bug splatter, old waxes, etc. As regular shampoos and clay don’t always remove old films of polish, High Definition Cleanser will effectively remove all surface residues as well as general dust and grime. This product has fillers that will mask minor surface imperfections
Chemical solvent paint cleaners are good to use if you want to prep the paint surface prior to applying a wax (without polishing). My preference would be to use a 1:10 isopropyl alcohol IPA / Limonene (P21s Total Auto Wash) solution or DuPont’s PrepSol as they don’t leave any (silicone / mineral) oils or etc behind, as these can cause problems when polishing if they are not removed
Formulated with solvents to remove old wax, embedded dirt and light stains from paint; they help to restore gloss and remove light surface imperfection. They are designed to be used as often as required without measurably reducing paint thickness
a) Abrasive
http://www.autopia.org/forum/welcome-greeting-center/] Authors Profile [/url]
