It should help, but where the clearcote is gone/failing you'll need to keep a good heavy wax or sealer on it to help slow the UV damage when it is is the sun.Izan747 said:thanks guys also if i start garaging the car do u feel it will slow it down ??
It doesn't really matter...... just get it worked into the paint as well as you can. You might want to try a glaze like Meg's #7 and then top it with a durable wax. All of the oils in #7 might help it look better for a while. That's just a guess on my part, I've never messed with CC failure that bad before.Izan747 said:also hand wax should be in a back and forth motion. and not a circular.?
