Hi everyone,
I have a few questions:
1. Is the cutting from a polish and a pad the same type of cut? I've read that pads have different cuts (say, lake country orange pad 2000 grit) and then I read polishes have them as well (menzerna sip 2000 grit), does that effectively remove a combined 4000 grit? If not, how does that work then? Because it would seem one could get by with using different compounds/polish on say, one white pad and relying on the grit level from the product every time and have good results. Or is the advertised 2000 grit from e.g. menzerna sip assumed to be accomplished with the orange pad?
2. Just curious, is the hardness, materials, or texture of the pad the difference and indicator of how much it will remove?
3. If using a more aggressive pad, are you always more than likely going to have to use another (less aggressive) polish step? If so, why is that?
Thanks!
Thanks!
