I've searched around and I can't find anything that really explains the relationship between DA pads and polishes and compounds.
I understand that wool is the most agressive pad and black foam is the softest.
I understand there are different amounts of cut in compounds.
However, what I don't get is the relationship between the two. Would it ever be appropriate to apply something like Ultimate Compound with a black pad? If you did such a thing would it would it do? Just cut slowly? Would it leave less marring than using UC with a yellow pad? Would you ever do one pass with a yellow then go over it again with a less aggressive orange pad? Does it ever make sense to use compounds with just a plain jane microfiber bonnet?
