Pad Washer Review
Jngrbrdman
I saw the Pad Washer in use at the Autogeek booth at the SEMA show this year. It seemed like anybody demonstrating polishing products had one at their booth. Autogeek had one at their booth too and I got to hear the inventors of the product talk about it a lot. So I decided it was worth giving it a shot. Holy cow!! Why didn't I get one of these sooner??? This is an absolutely awesome device that is a must have for anyone who uses a machine to polish their vehicles.
The product actually serves multiple purposes. It is a pad washer, pad dryer, wash bucket, and grit guard all in one. If you take out the center device that elevates the grit guard above the water level then it is a great wash bucket. Put the grit guard in the bottom and you get the added benefit of being able to scrub your mitt before going back to the car to keep washing. And we all know how much of a pain it is to wash out your pad and go back to polishing with it still damp. Spinning it on the highest setting will still only get so much of the water out. So this product is really a very versitile and useful purchase.
I let my son do the initial inspection and test fitting of everything. It got a big thumbs up from him. The thing I was really curious about is how intuitive this product was. If a 5 year old can figure out how to put it together and understands how to use it, then I am pretty sure anybody will be able to figure it out. ;)
After we got it put together and understood the rules, I put it to the test. It is the end of my detailing season and I had a lot of pads to wash. I rounded up as many as I could find and got ready to clean them. I think I might have missed a few in the garage somewhere... I could have sworn I had a couple more blue ones.
I did learn something interesting through this little experiment. I picked up my Porter Cable 7424 first to do the job, but I think the Flex 3401 is a little better at getting them clean. The entire motion of the Flex is gear driven and the pad doesn't stop spinning just because you put a little pressure on it. I cleaned a couple with the PC, but then I used the Flex for the rest.
I started at 20 after the hour and I put the last pad back on the shelf at a quarter till. It took me maybe 30 minutes tops to wash and dry every one of these pads. And that is considering I had to switch from the Edge 2000 adapter backing plate on the Flex to the velcro one halfway through.
After I poured out the water there was quite a bit of... something left in the bottom of the bucket.
I would say that is just proof that it works! Every one of those pads had been sprayed out, so this is also proof that spraying a pad cleaner and hosing them off isn't enough to get them clean. If you value your pads and want them clean then this is a must have product! Even if you don't care that much about your pads, if you hate polishing with wet pads and the resulting mess that they cause, then you still need to get one of these. It is a new must have recomendation for OCDetails.com for sure!
Question: I assume the pads are cleaned by spinning them against the grit guard. This doesn't abrade the pads in any way?
I ask because when I put a GritGuard in a rinse bucket, when I dip the white Shmitt in and lightly rub the schmitt against the GritGuard to clean it, it seems to rip the white material a little bit.
That may be an issue with the Shmitt that you are using. I've been using a grit guard for three or four years now and I've never had a problem with it chewing up my Shmitt. However, I can understand the concern with the polisher pads since they are spinning pretty fast on this thing. I had the same concern until I saw it in action. I watched the same pad being scrubbed clean dozens of times a day and it came out just fine at the end of the day. After cleaning a dozen double sided Edge pads and a dozen or more velcro backed pads I can tell you that the tool itself is certainly none the worse for wear. I'll keep everybody posted on the pad wear, but I expect they'll last a lot longer on this setup than they will on other pad washers that have gears and teeth that clean the pads.
Thanks! Makes me feel a little better about the abrading action.
The piece that the pads rub up against to clean is an actual Grit Guard? Same shape, protrusions, etc? Or is it modified? (Concerning the top surface of the Grit Guard.)
It is a standard Grit Guard with an optional little attachment that goes in the middle and creates sort of a raised speedbump. It is for deep cleaning when necessary. I like having it in there because it seemed to go faster with it there. Then when it is time to dry you just take that little speedbump out and attach it to the lid and it acts like an orange juicer in drawing the water out of the pad while it is spinning. It is an incredible invention that somebody really should have thought of before. Even LC doesn't have a better suggestion for drying out your pads other than spinning them dry. I don't know why, but that just never works for me. There is always way too much water left over. Doing it this way eliminates all of the water.
That makes me think of a good experiment. I can take one pad and dry it with the tool from the Pad Washer and I'll just spin dry another one. Then I'll hang them over a bowl to see how much water drips out of them after an hour or so. That should be pretty good evidence to the effectiveness of the tool I'd say. I'll have to do that next time I get a chance...
My wife is getting me one for Valentines Day. I know it will come in handy once spring gets here and I start detailing. I have 3 black cars to take of!
I got one after reading this review and used it for the first time yesterday after a headlight restoration job. It's fantastic. No more cleaning up all products and equipment after the job and then dreading washing the pads. No more standing over the sink and massaging each pad.
I did, however, lightly sand the Grit Guard with 2000 grit sandpaper first over 4 little plastic protrusions on the top. I did that to all my Grit Guards, which stopped the ripping of the Shmitt.
Plus I bought it at 20% off and free shipping.
