P21S wax
slowsilvy
I'm about to make my first big purchase and before I go spending a bunch of money, I was wondering about the P21S wax. It says it's great for red, black, and other dark colors, but my truck is pewter metallic (it's a silver/gold color). Are they saying it's great for those colors, and ok for others, or are they saying if you don't have those darker colors you're wasting your time? Being that my paint is metallic, it looks nice but doesn't seem to shine as well. I just want it to be as shiny as posible.
In my uses it has given an exceptional look on all colors. The downside is that you will be using it a lot, durability is not its high point. They also make P100S which gives the same look along with the same ease of application but it costs quite a bit less.
P21s is great on metallics as it will make the flakes pop and won't mute them. I recommend you get P21s100% as I have found that it has more depth and durability is slightly better.
Thank you, Detaildoc...
Also wanted to thank you, Slowsilvy for bringing up this topic. I was thinking about P21S 100%, too.
please do yourself a favor and get the S100...same wax....much cheaper.
Durability is not great but it is so easy to use and looks great that you won't mind using it once a month.
I've used it and it does look great but, as mentioned above, durability is not very good. But I don't care since I rarely go a month without waxing. And I apply via PC because I find that I can apply it faster and it goes on much thinner so I use less product.
