P21s drying towel
PA DETAILER
DETAILED TODAY?
P21S Super-Absorbing Drying Towel
against my better judgement, i washed the jeep this morning. (COLD!). figured it would be time to try the p21s drying towel. it arrives in a plastic container with the towel sealed. upon first use you must remove the towel from the container and run it under hot water along the edges, then gently unfold the towel. rinse it out very well! after i rinsed the jeep, i proceeded to dry it off with the towel. no drag. did not marr. did a fine job of removing the water. puts you in mind of the absorber, only smaller and just felt thicker. it removed 80 to 85% of the water. just had to finish with a drying towel. when done, rinse out well, and return it to the container. only gripe is the container is a bit on the small size. it can be machine washed. i liked it. for the price and the way it preformed, its hard to beat.
