Anthony A said:
I don't see how it's possible to not remove you LSP when claying. Claying can remove over spray so it will eat through was/sealant no problem. I think not removing LSP while claying is another Autopia myth.
Different clays, and different techniques, can yield different results.
If I were removing a significant amount of LSP, the areas I clay regularly would need redone a lot sooner than the areas I don't clay. As it is, the areas I clay the most often (like, the areas that get clayed almost every time) *do* need redone a bit sooner than the areas that never get clayed, but it's not anything drastic unless I've had to clay more aggressively than normal.
I've been doing this spot-claying since detailing clay came out in the early '90s, and I'm confident that I'm not somehow failing to notice anything.
I've posted before about my experiments with clay vs. LSPs, including how much I had to work at it just to cut through Meguiar's #5 (!). That was with Sonus green ultra-fine and Glyde lube, with my regular (very gentle) technique.
I've also been able to clay without killing the LSP using some slightly more aggressive clays, but there definitely is a limit to what the LSP can withstand. And different LSPs respond differently too.
And sure, I've cut off heavy overspray with aggressive clay, and I've marred the [crap] out of very hard paint with aggressive clays too.
But with a very mild clay, gentle enough technique, and enough lube that it barely contacts the paint at all, there shouldn't be a problem; the clay glides (heh heh, or "glydes" :chuckle: ) across the LSP on film of lube until it bumps into some contamination, which it then shears off. It never gets through the LSP (hardly even touches it) so it never contacts/abrades the paint.
IME this is one of those topics where you can only generalize soo far.
