Outdoor car covers, good or bad idea?
wolfe
My parking spot regularly gets hit by mist from the sprinkler system, which is very hard water (will leave spots). The water is quite a fine mist which gradually drifts onto the rear passenger side of the car, especially the wheel/brake disc. The sprinklers usually come on at around 10-11pm so going outside to dry the car off when they're done isn't really a viable option.
I'm considering a car cover, but on a new car with more eco-friendly paint and notoriously soft clear, I'm concerned it will make a real mess of the paint. Mazda makes a fitted cover for my car which is supposed to be soft and breatheable, though I am fairly sure it only reaches around 2/3 of the way down the wheels.
The mazda cover is under $140 I believe, so if there's an aftermarket one which is better, I'd like to keep it to around the same price, or less.
Are there any drawbacks/benefits to using a cover, or anything else I could consider (other than parking somewhere else!).
Thanks!
I also have the same problem at work but I get hit with a mists of tree sap. I believe theres a nice car cover at costco for around $30. Try it if u dont like it return it.
I use a truck cover that I got at Pep Boys for $70. Some :furious: stole my semi-custom cover (that was locked on my truck). Just make sure your car is clean before you cover. Use some detail spray and a microfiber cloth to get rid of dust before the cover goes on.
I'm all for car covers. If you get a good quality one, it can protect your paint from UV damage as well as the interior of the car. You will want a light moisture resistant cover. Some covers only protect from dust and nothing else.
