imported_Gary
what in the interior is made of leather. I have been detailing the interior, and I find some areas are hard to tell.
Splatter should be a non-issue if you apply product correctly. If you cannot pick up a bead with a rotary, use the orbital only. Apply the wax to the pad, smear it around a section of the car, then switch it on and apply a thin, even coat.
This is really a technique issue. However, if you feel you have done everything and you still get splatter, try a different wax. Something a little thicker may not sling as much.
Good luck. Let us know how things go for you.
Now I have a note from them that reads, "Quantity over Quality, 2 cars expected a day."
I have an orbital polisher, and a circular polisher. Lately I have been placing an "X" of wax across the circular polisher, and doing it section by section. Moderate speed and moderate splatter cleaning this way. With the orbital, I do the same thing more or less, and there is less splatter, but a slower working speed. I then tried applying the wax first to the car with an applicator, and then taking the circular polisher to the car, without anyway wax on the pad. This seemed to actually create more splatter.
SO, whats the best tool to use, and the best method to apply my wax to the car, and do a quick job, while minimizing splatter so I can clean up quicker?
