Orange CCS
RAG
I kinda like the looks of the orange CCS pad. Per this thread (http://autopia.org/forum/detailing-product-discussion/82381-if-u-could-design-pad.html), I indicated that I though the orange foam needed to be coupled with a softer foam underneath for rotary use...and I've had good luck with the orange LCVC pads to some extent, I just didn't like the cupped "variable contact" design. Other than the little holes/nipple gimmic, it looks like a good pad design.
Any experienced rotary guys tried this pad yet? I'm gonna order one or two tomorrow.
I've found the CCS pads to be excellent via rotary usage. They have a little more bite than the Hi-Gloss LC pads, so in certain cases less passes will be needed to improve or remove a defect. I haven't had much time to use them via a DA machine, but I would expect similar results.
Yeah, a little more bite makes sense, since the LCVC pads had much less contact area due to the concave nature (which is why I shave mine down, but then the foam was a little thin). Thanks.
And I'm sure they are superior (to the LCVC pads) via DA, as the limited contact area of the LCVC pads via DA really sucked. So for DA, I'm 100% confidnent these are an improvement...just not sure how they'll handle rotary action.
